Community Manager - Retired
Message 1 of 1
4OD rebrand FAQs
What’s Happening?
4oD has had a rebrand including a name change and a new logo. The app is now called All 4.
What’s New?
The service is still the same and will allow you to catch up on your favourite shows.  The only change is that it’s now called All 4.
What do I need to do?
You don’t need to do anything, just keep your YouView box connected to your BT Home Hub in order to get the software update which will include this change. Then you will see the All 4 logo appear in place of the 4oD app logo on your YouView box.
