Willrob60
Message 1 of 3
4k ultra box and tplink
I received my new 4k bt box today but it wont set up using my tplink powerline in my tv room. If i connect it to my other living room into the bt hub direct it works. Any suggestions why this is happening? Im on infinity 2.
2 REPLIES 2
iniltous
Recognised Expert
Message 2 of 3
Re: 4k ultra box and tplink
Is the power socket the home hub /1st power line adaptor connected to the same electric spur (ring main) as the the power socket the BTTV  box /2nd power line adaptor is plugged into ?...AFAIK both power power feeds need to have a common origin on the electric consumer panel/fuse board
Willrob60
Message 3 of 3
The poweline works perfect 30 to 40 mbps but then as soon as i connect the youview box it goes to zero as if there is a conflict. Bt have sent out their own powelines but im away with work for a few weeks now. Will try when i get home and let you know the result.
