echo69
Message 1 of 11
A second BtYouview box
I have one BtYouview box with the Esentail package, I bought a second Bt youview box for use in the bedroom, off E-Bay when I contacted Bt to take out the Extra box subscription to get the extra channels, all others bar the Bt Sport was working fine when I set it up to the internet conection, only to be told they could not get the Extra package at £5 a month, and that I would have to buy the box off them for it to work? I don't see why, if I want to add more contant on my main box they can do this but are unable to add the Extra package even though I am prepared to pay the extra for it.
10 REPLIES 10
Moderator
Moderator
Message 2 of 11
Re: A second BtYouview box
Hi @echo69 Sorry you could not get this ordered when you called.
We will be happy to check out if the Extra Box subscription is available if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
echo69
Message 3 of 11
Hi John sorry can't find how to contact you what info do you need please
Moderator
Moderator
Message 4 of 11
Hi @echo69 You will see a hyperlink just below my avatar to click here to contact the mods. It will take you to a form that will get the required information.
PS you may not see the link if you are viewing the website on a mobile device.
Post back if you are still having trouble contacting us.
Cheers
John
echo69
Message 5 of 11
Have managed to find the link and have fillede in the form as required, many thanks,
Stan
echo69
Message 6 of 11
Thanks for your help John my problem now has a solution provided by Gemma P ..Try as i might I can't click on the stare
Moderator
Moderator
Message 7 of 11
@echo69 That's great I'm glad Gemma got you sorted, there's a issue with the Kudo's at the moment you need to refresh the screen before it shows.
echo69
Message 8 of 11
Ok thanks NeilO tried that but no joy...
Moderator
Moderator
Message 9 of 11
@echo69 It's showing that you've clicked the star beside @JohnC2 and my posts.
echo69
Message 10 of 11
Ok right well it doesn't show up on my page on my laptop so there must be a problem some where. At least I am please you can see I was pleased.
Regards
Stan
