peter1uk
Message 1 of 6
AMC listings for next week
Is it just my box or does anyone else have the same tv listings on AMC for next week as this week?. This means that no series link is available for next week. Who provides these listings?.
5 REPLIES 5
Message 2 of 6
Re: AMC listings for next week
Hi,
Just checked mine and all seems ok!!
Silly helpdesk question, have you switched off the box, wait a couple of seconds and put it back on?? also, can you watch AMC at the mo?? if so your internet is most likely working '-)
cheers
CG Over An Out
Distinguished Guru
Distinguished Guru
Message 3 of 6
Peter1uk -- you are not alone the EPG details for AmC HD are incorrect for at least some of the days next week and different to the scheduled prograsmmes on the AMC UK TV website.
i suspect it will get correced in due course.
monarchjock
Message 4 of 6
As Zulu suspected it has sorted itself and my series record for Fear The Walking Dead has reappeared. 🙂
Distinguished Guru
Message 5 of 6
What is frustrating is that the YouView app and The BT app are often at odds and since you can set recording from both it is frustrating especially when you are as I am currently on holiday!!!
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Distinguished Guru
Distinguished Guru
Message 6 of 6
Actually I raised it on the Youview community and Sanj (Youview rep)  used their contacts to get a speedly resolution from AMC.
see
https://community.youview.com/youview/topics/amc-epg-listings
note their comment:
However any scheduled recordings set up in the previous week up until now may not successful record. We would recommend setting them up again to be sure they do record.
