emmacwilson
Newbie
Message 2 of 9
Adding an extra tv box
How come I ask BT how to add another box, one says it will be £6 a month extra and another said I can’t cause if my broadband package.
How do I get another tv box added onto my account
Tags (2)
8 REPLIES 8
emmacwilson
Newbie
Message 1 of 9
Been told I cannot add another box Tony account
Has anyone else had problems trying to add another box to their account, one BT staff said it would be £6 a month extra and another said they cannot do it with my broadband package, someone please help me add an extra box
Message 3 of 9
Re: Adding an extra tv box
-Richie-
Expert
Message 4 of 9
What speed is your fibre broadband ? It might be you don't meet the minimum requirement for a 2nd box subscription.
emmacwilson
Newbie
Message 5 of 9
It’s fibre unlimited 2
LittleHelper
Message 6 of 9
It's a good sign that you are of fibre 2 but it depends what speeds you actually get in your home. Depending on distance from the exchange and the cabinet you could be on fibre 2 and still only get slower speeds than is recommended for a second box.
It's possible both people you have asked were correct. Yes it's £6 a month extra for a second box but if your speeds are too slow to handle it they wouldnt sell it to you in good faith as you wouldn't be able to use both boxes at the same time.
Moderator
Moderator
Message 7 of 9
Hi @emmacwilson Please can you check your number on the Availability Checker and post a screenshot  of the result. Please edit out your phone number before posting the screenshot.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
emmacwilson
Newbie
Message 8 of 9
It won’t let me post to you or add an image in on here
Message 9 of 9
Here is how to post pictures.
 https://community.bt.com/t5/help/faqpage/faq-category-id/images#images
Do not post your phone number.
You cannot message @JohnC2 direct.
