MrT7
Message 1 of 4
Aerial pass through
I have a BAT Youview box (DTRT2100) and have used the aerial pass through to my LG TV. However every so often the Freeview channel which provides the HD channels is lost on the TV. If I retune, it comes back, only to disappear again later. This doesn't happen if I connect the aerial direct to the TV. Anyone got any suggestions?
Many thanks.
3 REPLIES 3
ozsat
Expert
Message 2 of 4
Re: Aerial pass through
Do you have auto standby set on the BT box? Is so ensure it is not the full power save option which I think still disables the pass-thru when active.
using Superfast Fibre 1 Unlimited with BT Max TV package (inc. UHD).
skappy70
Recognised Expert
Message 3 of 4
When your box goes into Deep Sleep the pass-thru signal to your TV is lost, you need to have Smart or Always On enabled.
Message 4 of 4
@MrT7Welcome to this user forum.
Are the HD channels lost on the BT YouView box when its connected to the TV using an HDMI cable?
