tractor37142
Message 1 of 12
All Freeview Channels lost
Yesterday (Sunday) weak signal message came up and no channels watchable.
I tried to retune channels and the bar skipped across in less than 2 seconds and found 0 channels.I then tried the box on another areal facing a totally different Transmitter with the same results.
A Factory reset had no affect but gaining acces to the maintenance menu and doing a Software reset (recommended) cleared the problem and all channels were re scanned.
This evening-the same problem (doh).
Help Please.
Brian
11 REPLIES 11
Telecom89
Recognised Expert
Message 2 of 12
Re: All Freeview Channels lost
Help Please.
Brian
Firstly can you see any of the internet channels that you had before e.g. BT Sport?
If you have no freeview channels take a look at: http://www.digitaluk.co.uk/help_and_advice/engineering_works#
to see if there's any work ongoing for your region.
You can also check this at http://www.bbc.co.uk/reception/ by putting in your postcode.
Can you check your aerial by plugging it into your TV directly and see if you can see the missing channels?
Telecom89
Recognised Expert
Message 3 of 12
tractor37142
Message 4 of 12
I spent over 4 hours trying all of the above sugestions yesterday morning when the fault first occured.
No Transmitter faults or Maintenenace,
TV's both working on different Aireals and Masts -(Redruth and Caradon).
Box tried on both and did get it to scan correctly after a software reset.
Then sometime during the afternoon It lost all FREEVIEW Channels again..
12 x INTERNET Channels working including BT SPORT.
BA
Distinguished Guru
Message 5 of 12
Is your tv itself able to get the channels ?
Sounds like an aerial or cabling problem. Ingress of water to the cable can cause these problems
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
tractor37142
Message 6 of 12
As ive stated above-TV signal to televisions is fine.Strengh over 60% and Quality 100%.
When I finaly got the box to rescan the channels (before it lost them again)the Signal Strengh was around the 60% mark and the Quality 100% so it is not a aireal or cabling problem .I have also tried it on two seperate feeds from two different aireals pointing to two sepearte Transmiters.
Software = 21.50.50
Comp =   2.9.34
Platform 1393
ISP      = 240
Resetting the Software this morning has not solved the problem.
Looks like I will have to make the Phone Call.
Distinguished Guru
Message 7 of 12
Good luck !
Helpful Post?
Jbkrek
Newbie
Message 8 of 12
Factory reset did not help me.
Moderator
Moderator
Message 9 of 12
Hi @tractor37142 and @Jbkrek,
Thanks for posting. Are you still having problems with this or did you manage to get it sorted? Can you let us know how you're getting on?
Cheers
David
Jbkrek
Newbie
Message 10 of 12
Still not sorted. Someone is coming out to check our communal aerial.
