Message 1 of 2
Altering the time on my box....
I have the MOST annoying problem - and BT don’t say ANYWHERE how to alter it! I need my bt box to have the time altered on it(the one that shows up on yr screen when you press “guide”. Everywhere time I record on iplayer,I am missing ends of programmes which is FRUSTRATING to say the least. Sky have automatic recognition on recording start/end programmes,so why don’t you BT I ask??
1 REPLY 1
Recognised Expert
Message 2 of 2
Re: Altering the time on my box....
You can't alter it.
Firstly , I'm confused why you've posted in the email section.
Secondly, I'm confused by your reference to iPlayer.
My assumption is that you're referring to the BT TV box (Youview) and setting a recording from the guide so I'll answer based on that assumption.
The problem is that YouView insist on using Accurate Recording (AR) which relies on the broadcaster sending accurate start/stop recording messages to the box. Some are good ,some are not.
If I've made a wrong assumption then I apologise.
