fredsmith
Newbie
Message 1 of 5
Amazon Fire Stick and MyTv
I have set up my Amazon Fire stick to watch BT TV in another room and am paying the £5 addition for the privalage but when I go to My TV on Amazon it says I need to update my subscription to view the My TV content I have recorded on my main TV.
Any help would be appriciated, thanks
4 REPLIES 4
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: Amazon Fire Stick and MyTv
Hi @fredsmith
If when you have logged onto the BT Tv app (on any device)  you navigate to settings  and then device management you should see the devices currently registered - there will either be upto  two or four slots depending  upom whether the BT Tv App Extra has been set up on your account.  How many devices do you see and is your Amazon Fire device one of them ?
fredsmith
Newbie
Message 3 of 5
All four and yes the fire stick is one of them
Distinguished Guru
Distinguished Guru
Message 4 of 5
Well that suggests your BtTv App extra is setup.
Now
http://bt.custhelp.com/app/answers/detail/a_id/62292/related/1
lists what you should see and have access to in the My Tv section of the app on Amazon Fire Tv
At what point(s) are you seeing the You must upgrade message(s)
fredsmith
Newbie
Message 5 of 5
I get the error message as soon as I press MyTv on the top menu
