AlexJC
Message 1 of 4
Amazon Prime Video app Issue with Netflix
Since logging into the Amazon Prime app I have to power off my BT TV box before I can then open the Netflix app, this happens consistently.  When selecting Netflix after opening Prime Video the loading pips show and the app fails to open. Anyone else having this issue?
Device: DTRT4000
Component software:3.7.8 (65c057)
Manufacturer software: 32.51.0
Tags (2)
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: Amazon Prime Video app Issue with Netflix
Hi @AlexJC welcome to the community and thanks for posting, I'm sorry to see you're experiencing problems opening the Netflix app on your BT TV box, I haven't seen any other reports of that particular problem but would firstly recommend checking the app software is up to date.
You can check if a software update is available manually at any time by going to:
And:
  • Settings > Software Information > Update software
  • Settings > Software Information > Update players and apps
If an update is available, your TV box will then download it automatically. Let me how you get on.
AlexJC
Message 3 of 4
Hi Neil
The software was all up to date as of when I raised this on the forum, I've not checked for a couple of days but it was still having the same issue as of 02/01/2020.
DavidM
Moderator
Moderator
Message 4 of 4
Hi @AlexJC,
Thanks for confirming that. There might not be a lot we can do with this but I'll be happy to take a closer look for you. I'll drop you a private message now so you can get in touch.
Cheers
David
