Message 11 of 16
Re: Android phone fails to find YouView box - failure code YVM 5010
This time the app refused to search with WiFi turned off. I turned wifi back on and as before, it failed to find the box.
Message 12 of 16
@Stubbington
But going into Airplane mode shouldn't turn off the WiFi, if it did are you not able to switch the WiFi only back on again?
Message 13 of 16
@Stubbington
Yeah, but did you use Airplane Mode first?
If you did try switching off mobile network manually without using airplane mode then try again.
Message 14 of 16
That did it! In airplane mode with WiFi restored it the app immediately found the box. Thank you so much for your patient assistance.
Moderator
Moderator
Message 15 of 16
@sea2dog wrote:
Solution I found was to go into Airplane mode then try connecting, worked for me.
Nice one @sea2dog Smiley Very Happy
Message 16 of 16
@Stubbington You're very welcome.
