jparnell82
Message 11 of 13
Re: Annoying purple glow at bottom of screen in rebranded BT TV Player
Hi,
I'm confused by the different terminology. Below are my current settings. By turning off 'fit to screen' the picture slightly enlarges and effectively hides the bottom glow. By doing this have i effectively just worked around the problem? Is this a fault with the new BT TV software that BT need to acknowledge?
Picture Size: 16:9 standard
Auto Wide: off
4:3 Screen size: off
Fit to Screen: off (was on)
Moderator
Moderator
Message 12 of 13
Hi All,  thanks for highlighting this issue. There is a defect in the player which isn’t removing the gradient from the playback bar from screen. This is in the process of being fixed and will be updated by the end of June. .
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
stereohaven
Message 13 of 13
Thanks for the update. Smiley Happy
