ADABERTHA
Message 1 of 3
Anyone know the dimensions of the BT Mini Connector?
I need to know the depth of the BT Mini Connector so it fits behind my wall mounted TV, please.
2 REPLIES 2
VeteranISPUser
Recognised Expert
Message 2 of 3
Re: Anyone know the dimensions of the BT Mini Connector?
Hi @ADABERTHA  I have always found the best source od information like this is Amazon. For example assuming it is the same model you are looking at - "Dimensions are: H12.7cm x W6.2cm x D4.9cm. The depth of 4.9cm is from the face of the wall socket to the outside of the flat front face of the Mini Connector; the curved portion at the top protrudes a further 0.5cm. When installed, the bottom of the Mini Connector is roughly level with the bottom of a standard MK wall socket. Don't forget that clearance is needed at the top for the Ethernet cable."
ADABERTHA
Message 3 of 3
Many thanks - back to the drawing board!
