findo_gask
Message 1 of 3
Aspect Ratio
I have a Panasonic Plasma. have Youview box connected through HDMI1. Previously had my Toshiba HD recoreder through this. Aspect ratio on TV was set to AUTO which gave no problems. With the Youview box everyone seemed thinner and car wheels slightly oval. By changing AR to 16:9 on the TV this is fixed. Is there something I'm missing on the Youview box settings ? No other gadgets need intervention to make the picture look right. My old Mummy 9200 was fine, my bluray is fine. It's no big deal as the workaround is not so bad but seems strange it's needed.
2 REPLIES 2
duncansby
Message 2 of 3
Re: Aspect Ratio
Same thing hapened to me following the last update - need to set TV to 16:9.
http://community.youview.com/youview/topics/aspect_ratio_constantly_changing
bobjob
Message 3 of 3
Re: Aspect Ratio
It seems to be a problem with Panasonic and Toshiba TV's,everything was fine until last update so its a box problem not the TV's,youview aknowledge there is a problem and are trying to sort it.
