antonyfrn
Message 1 of 5
Asus DSL-N66U does this router play well with BT Youview
Wondering if the DSL-N66U plays well with BT youview before i order one has anyone got any experiance with these ive noticed inthe firmware update notes some stuff todo with iptv. Would anyone recormend one of these for use with youview to replace a HH4 and ORModem?
4 REPLIES 4
ubysam
Message 2 of 5
Re: Asus DSL-N66U does this router play well with BT Youview
I Plumped for the RT-N66U and have been quite pleased - Bear in mind you'll still need the modem
Distinguished Guru
Message 3 of 5
I believe the DSL-N66U that the OP is after, does not need the OR Modem:
  • True two-in-one modem router with Ethernet WAN and DSL WAN
  • Dual system design offers more performance and flexibility for wired and wireless connections
  • Gigabit Ethernet ports for the fastest, most reliable internet performance
  • File and printer sharing via two multi-functional USB ports
  • ASUSWRT dashboard UI for easy setup, signal monitoring, and network application control
  • Auto-detecting ADSL/VDSL connection with CD/manual-free setup
  • Finest P2P experience via 300,000 concurrent data sessions
toekneem
(EASBF)
ubysam
Message 4 of 5
WHOOPS! My Bad.
Should work fine but may meed tweaking to ensure extra channels (multicast) are allowed through
ASUS RT-N66U
You must configure 'Enable VPN + DHCP Connection' to 'No' under the WAN option.
Settings used were:
- Have router on the latest firmware: 3.0.0.4.374.130
- Use the following settings in LAN > IPTV:
- 'Select ISP Profile' = None
- 'Choose IPTV STB Port' = None
- 'Use DHCP routes' = Microsoft
- 'Enable multicast routing (IGMP Proxy) = Enable
- 'Enable efficient multicast forwarding (IGMP Snooping) = Enable
- 'UDB Proxy (Udpxy) = 0
[From sepph's post]
https://community.bt.com/t5/YouView-box/Using-a-3rd-party-router-for-Multicast/td-p/1048582
CirenJules
Message 5 of 5
Hi,
My initial reaction was the same; however, when I upgraded from the N66U to the N-87R and Vigor 130 modem, everything (eventually) became clear:
http://www.snbforums.com/threads/ac87u-problems-with-bt-television.22319/
The above took a long-time to solve, hence wanting to share the solution; it looks like it's the modem...the ASUS plays very well with BT YouView 🙂
FYI - I'm now using the N66U as an Access Point in a different room to connect Sky+ and YouView boxes as well as boost the wireless signal into the rest of the house and garden.  Please note that YouView only works over a wired ethernet connection; buy some BT Extenders which use the electrical wiring in your house to go from the main Router to any secondary router (running in a different mode).
Hope that helps.
