Juliediontyler
Message 1 of 23
Asus DSL-N66U router settings IPTV
I've read a lot on here about settings for Multicast for other routers, problem I'm having is my router above running standard firmware doesn't have these same settings (no option to choose Microsoft routes etc), but is IPTV ready, I just can't figure out how to enable it to work. Anyone have the settings for this router?
22 REPLIES 22
TimCurtis
Recognised Expert
Message 2 of 23
Re: Asus DSL-N66U router settings IPTV
Should be exactly the same as the RT-N66U here
All Asus routers seem to require the same setting for IPTV to work.
ScottSilver
Message 3 of 23
In the 3rd Party Routers thread I did confirm this router works and confirmed the settings: https://community.bt.com/t5/YouView-Boxes/Multicast-Settings-for-3rd-Party-Routers-may-not-work/m-p/...
I strongly recommend you upgrade the firmware of the router if you haven't done so though.
Juliediontyler
Message 4 of 23
These settings do not work for me as I have the VDSL version and don't have the options listed on my firmware (newest available-updated twice to ensure up to date). For example, I have no setting for DHCP routes to point it to Miscrosoft. I enabled multicast and IGMP snooping but doesn't work so there must be something else? I have a checkbox for IPTV but there's no tick. Any ideas?
Juliediontyler
Message 5 of 23
I also don't have "Select ISP Profile" option.
TimCurtis
Recognised Expert
Message 6 of 23
Most surprised that under LAN/IPTV there's no DHCP option as all the current Asus routers look very much alike in terms of the overall firmware. My RT-N66U had it as does my DSL-AC68U.
Juliediontyler
Message 7 of 23
I have DCHP server options but I don't specifically have the option to choose the DCHP route (where they say to choose microsoft).  I can do screen shots when I get home if that would help?
TimCurtis
Recognised Expert
Message 8 of 23
That might a good idea.
WantageWill
Message 9 of 23
Have you tried Merlin's firmware. Works for me. Just maybe worth a try. n66.jpg
Juliediontyler
Message 10 of 23
Hi Wangtage, I'll give Merlin a shot. Thx for the tip!
