Yogi1474
Message 11 of 20
Re: Asus RT AC68U and Multicast
Good question! Looking at their website, it doesn't say it does, but also doesn't say it doesn't!
This is what is shows on the site:
  • ADSL & VDSL (FTTC/BT Infinity) Ethernet Modem
  • Bridge (pass) a single IP address or a whole public subnet
  • Ideal Partner device for DrayTek dual-WAN products
    or any other vendor's Ethernet WAN firewall
  • IPv6 and IPv4 Compatible
  • Ethernet Connection for client device (router, PC etc.)
  • Ideal for Apple™ Airport  devices
  • ADSL & VDSL Parameters pre-set for UK ISPs (adjustable)
  • Support for MTU1508 (Jumbo Frames)
  • VDSL Vectoring
  • PPPoA/PPPoE Bridging compatible with ISPs running IPv6
  • Protocol Support:
    • ITU-T G.993.1 VDSL
    • ITU-T G.993.2 VDSL2
    • ITU-T G.997.1
    • VDSL Annex A, Annex C, Annex M
    • VDSL Profiles: 8a, 8b, 8c, 8d, 12a, 12b, 17a
    • VDSL Vectoring
    • OLR, UPBO, DBPO, US0
    • ANSI T1.413 Issue 2
    • ITU-T G.992.1 G.dmt (ADSL)
    • ITU-T G.992.2 G.lite
    • ITU-T G.992.3 ADSL2
    • ITU-T G.992.5 ADSL2+
    • ADSL Annex L (READSL)
    • ADSL Annex M
    • PPPoA-PPPoE or PPPoE-PPPoE Bridging (WAN to LAN)
    • RFC-2684 / RFC-1483
  • Built-in Diagnostics (WUI / CLI)
  • Support for MTU1508 (Jumbo Frames) (Planned firmware upgrade)
zarf2007
Message 12 of 20
If it did support it they would list it. Do you have the old BT modem you could connect the asus to as a test?
Yogi1474
Message 13 of 20
The BT Home Hub5 allows the You View to work fine if it isn't connected via the Vigor modem.
Unfortunately, BT no longer supply a separate modem as the HH5 has on built in.
I've emailed Draytek to see if there's anything I can do with it, otherwise it looks like I'll have to buy another modem, which is a shame as I've only had this one for 3 months!
TimCurtis
Recognised Expert
Message 14 of 20
Picking up an Openreach modem off of ebay is the best bet. Go for the Huawei one in preference though.
Yogi1474
Message 15 of 20
Thanks Tim.
Do you know if this will need any additional configuration, or should it work straight off the bat now that my Asus router has all the correct settings?
Regards
Brian
TimCurtis
Recognised Expert
Message 16 of 20
Just plug in & go.
Yogi1474
Message 17 of 20
Excellent! Thanks again 🙂
Yogi1474
Message 18 of 20
Quick update: Have now switched the modem to a BT Openreach Huawei HG612, plugged in the Asus RT AC68U with settings mentioned in the earlier post and everything is now working perfectly. 🙂
Conclusion: Draytek Vigor 130 does not work with the BT internet channels! 😞
Thank you to all those that took the time to reply to my query.
Regards
Brian
pobz
Message 19 of 20
It worked for me, but I had to change the defailt in the Special Requirements ISP Settings to "Enable VPN + DHCP Connection" to NO befiore it worked, so thank you for that.
I called BT and they were of no direct use even though they kept on telling me I had to use their router, which doesn't work for me.  Glad it's sortred, thanks to you 🙂
CirenJules
Message 20 of 20
HI,
Whilst not directly relevant to the AC86U, if you find this page as you're strugglinggetting your pure ASUS Router working with BT TV and YouView then here's how I fixed the problem:
http://www.snbforums.com/threads/ac87u-problems-with-bt-television.22319/
I spent ages on getting this working; hence wanting to share and save other people wasting the hours I did.
