Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hello all
I have the BT TV MAX Package with a YouView+ Box along with Infinity 2 Fibre Broadband providing 72Mbs.
On some channels I get Audio Dropouts every couple of minutes for a second or two then the sound returns to normal only to happen again a couple of minutes later.
I have noticed this on a few Channels, for example Sci Fi, Eurosport, History etc.
The FreeView Channels seem to be unaffected for the most part.
I have tried swapping HDMI Cables between various Devices in order to track down the issue and everything points to the YouView Box.
Does anyone have any idea how to fix this issue?
Thanks in advance
Kevin
@kncowans - sorry for the issue you are experiencing. Please can you message me with the telephone number associated with your TV account. We would like to work with you to understand this issue more.
Hello Gavin
Thanks for the reply and the offer of help.
I actually decided to ring BT and spoke to one of the BT TV people.
Initially the response was that the issue was with the TV, however, since everything is connected via an AVR the TV is not a possibility.
After a while and since i had exhausted all avenues of troubleshooting it was agreed that a new YouView+ Box would be sent out.
I will provide an update here after i receive the new box.
Thanks in advance
Kevin
Hi @kncowans - thanks for the update.
If the new set-top box doesn't resolve your issue, I have some trial software I would like you to install to see if this resolves your issue.
If the set-top box swap does work, I would like to recover your old set-top box to send to Humax for analysis, if that's ok with you?
Either way, please let me know how you get on.
Hello
I shall post an update after i have had a chance to test the new box.
You are welcome to the old box if the new box resolves the issue.
Thanks in advance
Kevin
I've had this before ... do you have surround sound audio selected on the YV+ box? I did, and turning this off solved the issue for me.
hi had the same problem tried all reccomeded fixes by customer services. Tried other fixes as well but no luck.In the end the fault rectified itself or perhaps youview or bt did something on the quiet. Shame this happens a it has happened to me twice. Shall go over to Sky when contract is up. Never a problem with there boxes.
