david1982
Message 1 of 11
BBC 4k UHD trial
Noticed by recently whilst watching BBC iPlayer through TV wi-fi a short 7 minute UHD stream of Blue Planet 2, but this is not available on iPlayer through my bt UHD box
Does that mean we might miss out on BBC uhd broadcasts when(?) they start
10 REPLIES 10
Distinguished Guru
Distinguished Guru
Message 2 of 11
Re: BBC 4k UHD trial
i believe the BBC list the devices available at
https://www.bbc.co.uk/iplayer/help/planet_earth_4k
david1982
Message 3 of 11
Sorry point I was trying to make was that I saw this trial through smart TV iPlayer but it's not available through iPlayer with bttv
scointer
Recognised Expert
Message 4 of 11
I think the point Zulu was trying to make was that it is only certain devices that are available on the trial at the minute. YouView boxes are not one of the devices. That is why you can access it direct through the APP on your smart TV (if it is on the list) but not through the APP on the YouView box. As the trial widens hopefully the YouView app will be incorporated. As you can see on that list at the minute two of the biggest TV suppliers it is not available for (Sony and Samsung) so it is still very early days....
david1982
Message 5 of 11
Thanks Scointer for the information. All clear now glad I opted for LG not the Samsung I was thinking about.
gibbylinks
Message 6 of 11
The whole series is now avaliable for a month
https://www.bbc.co.uk/iplayer/help/latest-news/blue-planet-II-uhd
Are their any plans by BT to upgrade the Iplayer on the UHD box so it can play the 4k content?
MadRob
Message 7 of 11
That would be a decision for the BBC to make, not BT. The iplayer is supplied to BT/Youview by the Beeb.
pompey1898
Expert
Message 8 of 11
I know this is an old thread but did not want to start yet another one.
Is anyone having problems watching Wimbledon on BBC iPlayer please ?
Tags (1)
gibbylinks
Message 9 of 11
Iplayer working fine for me
pompey1898
Expert
Message 10 of 11
Hi @gibbylinks ,
Thanks for the reply.
So did you manage to keep a coonection to Centre Court all, or most, of the day ?
What did you think of the picture quality ?
