Otlord
Message 1 of 2
BBC b HD multiplex channels missing
Hello everyone,
I have a Humax box (DTRT1000) running YouView version 27.50.0. I get 162 channels, including all the channels on the com7 and com8 HD multiplexes, but none of the HD channels on the BBC b HD multiplex. I am on the Mendip transmitter, which should have all 3 multiplexes, according to Digitaluk.co.uk. This hasn't suddenly happened - it has always been the case. I have no reception problems with the other channels - signal strength is good. Could this be a Humax hardware / YouView software problem? Any advice would be gratefully received!
Yours sincerely,
Oliver
Tags (3)
1 REPLY 1
BT TV Expert
BT TV Expert
Message 2 of 2
Re: BBC b HD multiplex channels missing
Hello @Otlord
If you would like to Private Message me either your phone or account number, i'll look into this with one of our Freeview experts and let you know the outcome.
Kind regards,
Martin.
BT TV expertMartin
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
