Message 11 of 18
Re: BBC iplayer not staying logged in
Hi, I'm still experiencing this problem and it now blocks me from accessing the service.
Distinguished Guru
Distinguished Guru
Message 12 of 18
Just checking @IAT  are you experiencing the issues on a Youview box and if so have you tried any other devices ?
Message 13 of 18
Yes, on the YouView box, but not if I use my Smart TV directly and not through the box.
Message 14 of 18
I’ve got this issue now. It started a week or so ago. Our sign in details aren’t retained and so we can’t log in automatically or switch users.
Newbie
Message 15 of 18
i also have this issue on a Toshiba Smart UHD TV bought yesterday.  Is there any fix?
Message 16 of 18
I did a factory reset, retaining recordings.  Instructions here. Fixed it. http://bt.custhelp.com/app/answers/detail/a_id/48051/~/how-do-i-reset-my-bt-tv-box%3F
Message 17 of 18
Thanks for the suggestion. I tried it but was still asked to do the registration again. I'm signed in when using my laptop or directly on my Smart TV.
Message 18 of 18
Registration or login? I had to log in again, but then my login details were retained.
