markbenfleet
Message 1 of 5
BBC news channel had 107
Why can’t I get this channel, I have the total entertainment package but have retuned several times but this channel has disappeared??
4 REPLIES 4
ozsat
Expert
Message 2 of 5
Re: BBC news channel had 107
107 is not a part of the BT line-up but is a Freeview channel.
If you've lost it it will relate to your own tv aerial signal.
using Superfast Fibre 2 Unlimited with BT Max 4K package.
gomezz
Recognised Expert
Message 3 of 5
Note that it is on the COM7 Freeview MUX which is broadcast at a lower power than the other MUXes. You will find BBC 4 HD is also missing.
Scotsmantom55
Message 4 of 5
I have same issue. You can get it in SD on 231
ney
Expert
Message 5 of 5
I also have minor issues with BBC News HD on channel 107. Along with other channels on coms 7 when its very windy or heavy rain outside.
As said coms 7 broadcasts on less power than the other muxs on Freeview.
Darren
