4KTVFan
Message 1 of 7
BT 4K UHD Box keeps turning itself off
Hi, this is more a support question.
My BT 4K UHD box, which is now 2 years old has started to randomly switch itself off, I thought at first maybe the box was over heating, but when I feel the box after it's randomly shut down it's hardly warm.
Today it shut down 3 times, so it feels like it's getting worse.
Is this a failling box, and if so, how do I replace it?
6 REPLIES 6
Distinguished Guru
Distinguished Guru
Message 2 of 7
Re: BT 4K UHD Box keeps turning itself off
Can you clarify what happens .
is the box going into standby  mode unexpectedly  or is it rebooting  or freezing ?
and what happens next  ie does it respond to the remote  and restart and how does  it restart .. ie with a reboot or does it display a Youview screen or channel.
Probably also need to consider if is this potentially a power supply issue  ?
4KTVFan
Message 3 of 7
Hi @zulu17
Thanks for answering my post.
From what I can tell, the box is not rebooting or freezing.
I believe it's just turning off, or as you say, going into standby mode, because I can bring it back in immediately with the remote's power button.
I thought it was the box over heating, but as I said, when I feel the box it's hardly warm.
As for checking the power supply, not sure how to do that other swapping it out with another one, which I don't have.
I can see what's going to happen, my box is to fail right before Christmas! Smiley Frustrated
4KTVFan
Message 4 of 7
So I think the problem maybe the box going in to standby after a certain period of time, I've seen a message come up at the top of the screen saying you have 1 minute to press OK or the box will go into standby.
But if I'm in another room, or making a cup of tea I can easily miss that warning message, 1 minute is not long???
If there any option to switch this option off?
Distinguished Guru
Distinguished Guru
Message 5 of 7
Hi @4KTVFan  If you go into  Youview > Settings > Box Management>Power&Standby
you should see option for Automatic Standby which you can adjust to one of 2 , 3 , 4 or 12 hours.
4KTVFan
Message 6 of 7
Thanks @zulu17
I've never looked at that setting, it was set to 3 hours, I've now set it to 12 hours.
Let's see how things go now...
4KTVFan
Message 7 of 7
So thanks to @zulu17
I've set my box to 12 hours standby, it was on 3 hours, and my problem of box randomly turning of have gone.
Not sure why I've never seend this before... strange...
