Message 1 of 3
BT 4k UHD Box
I received my new 4k uhd box today plugged in and everything seemed OK. None of the sports channels were working neither was AMC or any of the now TV channels. I was told this could happen up to 11:30pm. Then at about 11:00pm the box started to reboot itself. It did it about 5 times. Thinking it was updating the channels, I left it to do its thing.
It then said the channel signal was lost and rebooted again and again and again. It is now stuck in a boot loop.
I have tried unplugging the box and leaving it 10 minutes but that has made no difference to it.
 I have also tried getting into the maintenance menu but the same thing happens it just keeps boot cycling.
It has the code UKTFAF 0.07 in the top left corner.
2 REPLIES 2
Moderator-Retired
Message 2 of 3
Re: BT 4k UHD Box
Hi @Kev72,
Welcome to the Community and thanks for taking the time to post.
It sounds like you have received a faulty box, sorry about that. Can you call 0800 800 151 to report the box faulty so we can have it replaced?
Matt
Message 3 of 3
Re: BT 4k UHD Box
Thanks @Matt-S spoke to a guy yesterday on the contact number who was very helpful and is sending me a new box out.
Thanks for all your help 😀.
