Arsilias
Newbie
Message 1 of 3
BT Entertainment Channels / BT Player Randomly Disappeared..
So basically everything was fine last night, Internet channels working fine, come to watch TV just now and no Internet channels / BT player...
Have reset box, router.etc and still nothing, Netflix.etc works perfectly fine as do the standard catchup apps.
Anyone care to share any ideas? Slightly peeved as these are the channels I actually pay extra for!
2 REPLIES 2
Arsilias
Newbie
Message 2 of 3
Re: BT Entertainment Channels / BT Player Randomly Disappeared..
Might as well ignore this, updated box yet again and finally got it sorted
Moderator
Moderator
Message 3 of 3
Thanks for letting us know you've sorted it Arsilias. Post back if you have any further problems.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
