GarryJ
Message 1 of 2
BT Extra box speed Required
Just wondering what would be the maximum speed required to run the extra box option without constant buffering etc. I have been wondering to get this service for a while now, but worried that my usual speed i can get here, of around 30mbps, is far too slow to run extra box without problems, i thought the online option of ordering would say if i did not have enough speed to run it, but i went all the way through to the "checkout" option with nothing being said before i cancelled as i was worried about this issue, anyone have any ideas? Thanks for all your help in advance!
1 REPLY 1
NeilO
Moderator
Moderator
Message 2 of 2
Re: BT Extra box speed Required
Hi @GarryJ Thanks for posting, the minimum speed required for the extra box subscription is 23Mb on FTTC.
