CraigRichards
Message 1 of 3
BT Home Hub 5 wont connect to internet
I have the internet blue light on my router and internet works fine around the house but i only have one blue light on my Home Hub box and says it cannot connect to the internet. It is connected via an ethernet cable that has worked for a couple of years but recently i have had to try restarting each device hoping that it connects again. sometimes it works but each day it says internet not connected again.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: BT Home Hub 5 wont connect to internet
Hi @CraigRichards,
I'm sorry your having problems with your connection. Have you tried factory resetting your hub to see if that improves things?
How do I reset my BT Hub to its factory settings?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
CraigRichards
Message 3 of 3
Cheers Paddy, i unplugged my router and home hub connections and must have put the ethernet cable into a different port out of the 4 that are available than i previously had it in, because trying the cable in different ports i dont get that problem any more. if it doesnt cure the problem in the future i will look to reset to factory settings, thanks for the support.
