albert123
Newbie
Message 1 of 3
BT Humax DTR T1000 "Nearly Ready" problem
New to this forum.
Having scoured this forum for a fix to this problem and not found anything, am I correct that I have to bin the box and buy a new one?
I have had the box for about 2 - 3 years. No problems until about a month ago. Took the hard drive out and it appears to be OK connected to a Linux box and running a disk check on it.
Have re-flashed the box firmware. Done a factory reset. makes no difference.
Any ideas?
2 REPLIES 2
Telecom89
Recognised Expert
Message 2 of 3
Re: BT Humax DTR T1000 "Nearly Ready" problem
Hi
Might be worth you asking on the 'hummy dot tv' forum (not allowed to post a direct link here afaik)
In particular, see the posting titled: DTR-T1000: recovering from 'Nearly Ready' in their YouView forum.
albert123
Newbie
Message 3 of 3
Hoorah! Managed to fix it.
How? I replaced the 500GB hard drive with a new one. Put the T1000 in 'maintenance mode' , selected 'USB firmware update - delete recordings', follow the on-screen instructions and let it do its stuff. After setting up, it is back to as good as new.
No idea what is wrong with the old hard drive - I conneted it to a Linux Mint PC and did a thorough disk check and it came up OK, no errors. I can even play most of the recording on the disk on the Linux Mint PC. It is possible that there is a corrupt system file on the disk that is caused the problem - though I would have thought that the operating system in the T1000 (Linux?) should have detected and repaired it.
I will try and transfer my recordings from the old disk to the new disk - see how easy or difficult that is to do. Watch this space!!!
