Jiffy1
Message 11 of 20
Re: BT Internet channel break up
Hi Keith, I reported a noisy line, and the guy said there was no fault, even though I can hear shooshing noise while talking to him! So where do I go from here. Thanks.
Keith_Beddoe
Message 12 of 20
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Jiffy1
Message 13 of 20
Thanks for your help Keith, have a good day.
RobbieMac
Moderator
Moderator
Message 14 of 20
Hi @Jiffy1
Thanks for posting back.
I have sent you a private message with advice on how you can get in touch with us.
Cheers,
Robbie
NeilO
Moderator
Moderator
Message 15 of 20
Hi @Jiffy1 did you get the chance to set up and try the new powerline adapters? Post back and  let me know if they've helped.
Jiffy1
Message 16 of 20
Hi Nial, been trying the network adapters in various ways, come to conclusion its probably my house wiring causing problems. If i put the adapter in the back room and run a long LAN vable round to it, it works perfectly, If i connect laptop and do a speedtest i get between 50 to 65 mbps, putting adapter in original place, still getting break up, and speedtest results of 0.5 to 11 mbps......So, in conclusion seems like wiring not supporting adapters. I'm waiting on a call from my sparks, maybe he can put both the circuits i need on the same BUS, will let you know. Thanks for all your help.
NeilO
Moderator
Moderator
Message 17 of 20
Hi @Jiffy1 thanks for the update and sorry about the delay getting back to you.  Those checks do point to a problems with the electrical wiring especially when they work without issue on the socket located in your back room. I really hope your sparky can come up with a solution for you and please do post back to let us know the outcome.
Jiffy1
Message 18 of 20
Thanks Neil, he hasn't answered yet, prefer him as he knows the layout maybe. Will keep you posted.
Jiffy1
Message 19 of 20
Hi Neil, Today i managed to get my adapters working properly, i have run an extension through the wall to a socket which is on the same ring as my router! can now have 2   4 k videos playing, spotify, and laptop all at the same time. Happy bunny. thanks for your help.
JohnC2
Moderator
Moderator
Message 20 of 20
Hi @Jiffy1  thanks for posting back and good news to hear all is sorted. I'll let @NeilO  know it's fixed.
cheers
John
