Message 1 of 10
BT Player and entertainment channels not working
Hi I have this problem but the above has not resolved the issue. I have called BT numerous times as I beleive they have not activated my BT TV correctly but they don't appear to be able to resolve this
9 REPLIES 9
Message 2 of 10
Re: BT Player suddenly has stopped working, entertainment channels not working
I can't spend another hour on the phone to get nowhere so any assistance would be welcomed
Moderator
Moderator
Message 3 of 10
Hi @Shadley1000 Sorry that you are having a fault with your BTTV service. I've moved your post to create your own thread as the previous thread has already been resolved.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Expert
Message 4 of 10
Re: BT Player and entertainment channels not working
yep same here, 3rd time in as many updates here. You have to do a reset/keep recordings if that procedure you linked to doesn't work. Good luck !
Message 5 of 10
Ok I have tried the factory reset and still no luck .. During the reset it said I do not have BT TV ... It also says this on my account when I trouble-shoot ... It's pretty clear BT have not activated this but nobody can help when I call up and they keep putting me on hold and then cutting me off ... So close to cancelling and getting Sky
Expert
Message 6 of 10
I think you have a different problem to be acutally. I get problems when trying to watch in the early hours (3-4 am). I wonder if it's because BT is doing a lots of box upgrades that some how slow the network down.
Yesterday I got some IPC erors again and non of the recorded programme thumbnails were showing up,  however power cycling the router solved it.
Message 7 of 10
@srpsrp
There is a known issue which Youview have posted on in the Youview Community forum as being currently under investigation re missing thumbnails. It's something I think they have found difficult to pin down as to the reason for this behaviour as it manifests itself at random times and on random channels.
Moderator
Moderator
Message 8 of 10
Hi @Shadley1000,
Thank you for sending in your details and for taking my call today. I've ran a few checks on your service and I've picked up a mis-match with the TV service and Broadband. This has been corrected, you'll need to restart your BT TV and Hub.
If it isn't working right away, check for a software update in the BT TV settings and lastly try launching the BT player. This will refresh your entitlement and should get the TV service working again.
I'll give you a call tomorrow to make sure that back working for you.
PaddyB
Message 9 of 10
Hi Paddy thanks for your call ... Everything is working now and we have everything we are subscribed for ... Cheers for resolving this for us
Moderator
Moderator
Message 10 of 10
Hi @Shadley1000,
Thank you for posting back, I'm happy to hear your BT TV is back working for you Smiley Happy
PaddyB
