Good evening,
I am getting this error code when trying to access bt player and national geographic TV,
I have been through the other posts and tried the reboot, reboot, reset as suggested and this has not worked, I have been unable to get through to tech support on chat and don't want to phone as they suggest.
Would it be possible for one of the tech guys on here to have a look for me please?
I did, thank you. I have reset both router and box, and then factory reset the box, still receiving the error code
If that post is anything to go by, then it sounds like an account problem, if so you will need help from a moderator to sort it.
Hi @pjt1980,
Thank you for posting, I'm sorry you're experiencing problems with your BT TV service. With everything that's been posted, it looks like its a problem with the account. If you send me in your details, I'd be more than happy to take a look at this for you.
I have sent you a private message with instructions on how to contact me. You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
PaddyB
