f1charlie
Message 1 of 5
BT Pro box number of simultaneous recordings
I thought the Pro box could do three recordings simultaneously, but I managed to do 4 simultaneously the other night.  I thought it might have been a bug when I didn't get a warning when I set them all, but they all appear to have recorded successfully.
Is this an update that's been sneaked in unannounced?
4 REPLIES 4
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: BT Pro box number of simultaneous recordings
The user guides I  believe  says
You can record up to 4 programmes at the same time. If you record a fourth programme, you can’t then watch a fifth on live TV. You can still watch something in an app or a programme you’ve already recorded"
You will have the normal limits on the number of multicast channels than can be accessed for recording/viewing simultaenously.
jam2000
Recognised Expert
Message 3 of 5
I'm able to record 4 freeview channels and 2 Now channels, so 6 in total also I'm able to watch a recording while recording those 6
f1charlie
Message 4 of 5
Thanks all.  I don't know where I got the 3 recordings from!
zulu17
Distinguished Guru
Distinguished Guru
Message 5 of 5
@f1charlie  i suspect you read the news releases in June
