terry821
Message 1 of 16
BT Pro remote
Just received delivery of my new BT Pro box. Very impressed.
However I can’t get the remote to control the volume on my TV. It does appear to turn the TV off when I press the BT button, anyone know how to reset it or force it to update?
15 REPLIES 15
NeilO
Moderator
Moderator
Message 2 of 16
Re: BT Pro remote
Hi @terry821 welcome back to the community and thanks for posting.  I'm sorry to see you're having issues with your BT TV Box Pro remote
If you need to re-pair your remote, follow these quick steps:
  1. Press the Home and 9 buttons at the same time
  2. Hold down the buttons until the LED around the BT icon flashes purple three times
Post back and let me know if that helps.
Neil
terry821
Message 3 of 16
Re: BT Pro remote
Yep that doesn’t work either I’m afraid.
 The blue light flashed however it doesn’t seem to pick pair to my tv. tried it several times.
NeilO
Moderator
Moderator
Message 4 of 16
Re: BT Pro remote
Hi @terry821 thanks for giving that a go, I'm sorry it didn't work. I've a few more checks to try.
If it won't control the TV, try the following:
  • Connect the TV directly to the TV box using the HDMI cable supplied
  • Make sure the HDMI cable doesn't connect through an audio device (Soundbar/Surround sound) and is not connected through an HDMI switch
Once you've removed any additional equipment, try controlling the TV again.
Neil
terry821
Message 5 of 16
Re: BT Pro remote
Thanks Neil.
The box is connected directly to the TV via the HDMI provided.
The pairing now seems to control the TV box volume rather than the TV itself.  Is there a manual option to enter a code for the make/model for the tv?
NeilO
Moderator
Moderator
Message 6 of 16
Re: BT Pro remote
Hi @terry821 I'm sorry about that, not all TV's are compatible with the remote. Can I ask what the make and model of the TV is and I'll raise this with our TV experts?
Neil
terry821
Message 7 of 16
Re: BT Pro remote
Amazon Fire TV edition – JVC 4K (2019)
ozsat
Recognised Expert
Message 8 of 16
Re: BT Pro remote
It says on-screen that you can not change the volume using the volume keys if you are in 'Surround' audio mode.
using Superfast Fibre 2 Unlimited with BT TV Box Pro (UHD/HDR).
ozsat
Recognised Expert
Message 9 of 16
Re: BT Pro remote
After a reboot - the volume is now working - and still in 'Surround' mode.
It is controlling the (Panasonic) tv volume - which in turn is controlling the amp.
The stb is connected via the (Yamaha) amp.
terry821
Message 10 of 16
Re: BT Pro remote
how do I reboot? Is that a soft reset or just simply turn the back on and off?
