woodburn
Newbie
Message 1 of 4
BT Sport on Talktalk Youview+ Box
Hi,
Apologies if this question has been answered previously but a good scout about on the internet and I couldn't find the answer.
I have just changed from Talktalk to BT for fibre and BT sport.  I have been sent a BT Youview box but still have my Youview+ Box from Talktalk.  Is it possible to continue to use the Talktalk Youview+ box in and watch the BT Sport channels on it?  I didn't clock that the included BT youview box lacks the ability to record TV and buying another BT Youview+ box (seem to be available for around £50 online) seems like a waste given I already have a working Youview+ box (albeit from Talktalk).
Thanks for any help received.
3 REPLIES 3
Message 2 of 4
Re: BT Sport on Talktalk Youview+ Box
Welcome to this user forum.
You may get a more comprehensive reply, but as fas as I am aware, once you connect your TT YouView box, it should rebrand itself as a BT YouView one.
You may have to factory reset it, but you should then get all the sevices you have paid for.
You would not be able to use that box, and the non-recordable one together, without paying extra.
woodburn
Newbie
Message 3 of 4
Many thanks, will try the factory reset.
We only have one TV, no aspirations to use more than one box!
woodburn
Newbie
Message 4 of 4
Sorted. Thanks for the help!
