Message 1 of 3
BT Sport picture break up Help
Scenario.
rejoined BT TV. Picture break up on original box, solved by a factory reset.
upgraded to HD and got BT Box Pro.
worked like a dream till yesterday. HD unwatchable SD fine.
rebooted box, router etc no avail. Speedtest fine steady at 24mbps.
factory reset box. No alteration still unwatchable HD.
Frustrated. Have now put in a cancel order for HD.
Any advice? BT Sport streams perfectly on TV via app and via Apple TV in HD.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
2 REPLIES 2
Message 2 of 3
Re: BT Sport picture break up Help
Hi @stuartrogerson
Is there a second Youview box connected to your line ?
Message 3 of 3
@zulu17  Nope. Think I just solved it by rebooting the powerline adapters.
Helpful Post?
