dnewitt1
Message 1 of 8
BT Sport without TV subscription
Hi,
If i have a Youview box supplied from BT but no TV subscription can i receive BT Sports if i have BT Infinity?
Hope that makes sense.
7 REPLIES 7
Distinguished Guru
Message 2 of 8
Re: BT Sport without TV subscription
No, first you need a BT TV subscription. Then you need to order the free BT Sport pack to get the channels added to your BT TV entitlements.
See  http://bt.custhelp.com/app/answers/detail/a_id/43272/c/6401,6611,6611
notoriousdbp
Recognised Expert
Message 3 of 8
As umpire says you wouldn't be able to get it through your YouView box, however you can watch online on your PC or via the Ipad / Android app
---Remember to mark as 'solved' and give stars when you like a post---
dnewitt1
Message 4 of 8
Thank you for the reply
fredlian
Newbie
Message 5 of 8
thats great i dint know that bt sport also had an app for android that we can watch the games.
im not a bt costumer so how much will cost me?
Guru
Message 6 of 8
Hi, it is free with BT Broadband. Not available to purchase separately.
Stew
shoneymk
Newbie
Message 7 of 8
If you buy a youview box from BT, will you get BT Sport without adding the BT TV package?
Guru
Message 8 of 8
No, see Umpires answer above.
Stew
