DCDC
Message 1 of 20
BT Sport
Hi
Looking for guidance on how to get around a problem with BT Sport.
After watching any of the BT Sport channels for around 10 minutes the poicture freezes, sound drops and then a blank screen. Press TV guide on remote twice and picture and sound come back. After five minutes the same happens and I repeat pressing the remote, picture comes back and so on. This has been happening for over a month. The BT box is "YouView" by Humax and the hub is a SmartHub.
So far I have:
Checked connections at hub and box.
Switched box and hub off and on.
Factory reset both
Checked software is up to date
Reduced picture from 1080p to 1080i
Completed broadband speed check
Completed BT troubleshooter at least twice
Used the live chat support.
I can watch; Netflix, Prime Video and iPlayer with no problems whatsoever.
Anything else I can try?
19 REPLIES 19
Moderator
Moderator
Message 2 of 20
Re: BT Sport
Hi @DCDC sorry you are having a problem trying to watch BT Sport on your Youview box.
You have said the problem has been happening for the last month. Did the service work ok before then or did you just activate BT Sport a month ago?
You have checked the connection between the hub and the Youview box already but is this an Ethernet or powerline connection?
What model of Youview box do you have?
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
DCDC
Message 3 of 20
Re: BT Sport
Thanks for your reply John.
The service worked satisfactorily from Jan 2018 until November 2018. It is an ethernet cable from hub to box. An initial thought was that there was a problem with the cable. However, if Netflix, Prime Video and iPlayer are working , I discounted that possibility. Equally, if it was the cable, I belioeve it would not work at all.
Dugald
Moderator
Moderator
Message 4 of 20
Re: BT Sport
@DCDC Thanks for confirming that, what broadband speed did you get when you checked the connection?
These issues are normally caused due to an problem with the connection speed the Youview box is getting. Netflix and iPlayer etc don't need as fast a connection as they are delivered differently over the broadband connection to the live Internet channels.
Community ModeratorNeilO
Kudos”
DCDC
Message 5 of 20
Re: BT Sport
Hi Neil
The connection speed is 42.4mb/s
Thanks for clarifying position with Netflix and so forth.
DCDC
Moderator
Moderator
Message 6 of 20
Re: BT Sport
Hi @DCDC,
I think it would be best if we could test your connection and get to the bottom of this for you. To get in touch with us, click on my user name and then copy and paste the link under "Moderation Team Email Address" into your browser.  Complete that form and we'll get back in touch with you.
DanielS
Community ModeratorDannyS
Kudos”
Moderator
Moderator
Message 7 of 20
Re: BT Sport
Hi @DCDC thanks for sending over your details. I have referred the case to our BTTV experts and they are currently investigating this problem. I will keep you updated of progress.
Cheers
John
Kudos”
Moderator
Moderator
Message 8 of 20
Re: BT Sport
Hi @DCDC I called earlier sorry I could not reach you. I wanted to check how the engineer visit went yesterday. Post back and let me know how you got on.
Cheers
John
Kudos”
DCDC
Message 9 of 20
Re: BT Sport
Hi John
Sorry couldn't take calls. Busy day.
Engineer came and ran a few tests amd could find nothing wrong with broadband. The fault is not remedied.
I told him that I could watch BT Sport on ipad with no problems. We switched on both TV and ipad to watch BT Sport on same channel. TV cut out and froze after around five minutes but we could continue to watch the channel on ipad. Therefore, this suggest that all is ok to the Hub but there is probably an issue with the BT Vue box,
He tried to get offshore support which was a compleye waste of time.
Can take calls all of today, Friday 25th. Don't go haggis hunting until this evening.
Thanks Dugie
Moderator
Moderator
Message 10 of 20
Re: BT Sport
Hi @DCDC,
@JohnC2 is out of the office right now so I've ordered a replacement Youview box for you to see if it makes an improvement or not. I'll send John an email so he can check the order tomorrow to make sure it's going ahead ok. He'll be in the office later today.
Be careful with those lil haggis. They can sneak up on you when you least expect it Smiley LOL
DanielS
Kudos”
