Moderator
Moderator
Message 11 of 20
Re: BT Sport
Hi @DCDC I called earlier sorry I could not get to speak with you. The BTTV experts have checked and there are still to many errors on your broadband connection and have asked for a 3rd appointment to reduce these errors. I need to book a suitable appointment and will call again on Monday am when I am back in the office.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
DCDC
Message 12 of 20
Re: BT Sport
Hi John
Installed new equipment. No change. First channel BT Sport  1, not HD, failed after nine minutes. Second channel, BT Sport 2, not HD, failed after seven minutes.
cheers
Dugie
Moderator
Moderator
Message 13 of 20
Re: BT Sport
Hi @DCDC thanks for the update and hopefully the engineer visit tomorrow will fix the issue with the errors on the connection.
Cheers
John
Kudos”Kudos”
DCDC
Message 14 of 20
Re: BT Sport
Hi John
Update.
The third engineer has just left. Like the previous engineers he confirms that the line is good. The engineers are obviously skilled, one of whom was a senior engineer and another  who deputises in management. Therefore, I have no reason to doubt them.
The engineer and I contacted the offshore call centre. After a drawn out process of spelling names and so forth they were able to verify that I am a customer. The call centre operative wanted to run tests on the box. I advised the person at call centre that the youview box was a new one and had been installed yesterday. But, run the tests we did. The result is that a new viewbox is being dispatched and I’ll receive it in a few days.
Once I receive box and set it up I will advise you of the outcome.
Cheers
Dugie
Moderator
Moderator
Message 15 of 20
Re: BT Sport
Hi @DCDC Thanks for the update and I will update the BTTV team and await the engineer's report and get back to you as soon as I can.
Cheers
John
Kudos”Kudos”
DCDC
Message 16 of 20
Re: BT Sport
Hi John
Problem remedied. The BT TV people completed a card reset on the line. They will continue to monitor the line over the weekend and will contact me by email next week.
cheers
Dugie
Moderator
Moderator
Message 17 of 20
Re: BT Sport
Hi @DCDC Thanks for the update and good news and hopefully it works perfectly over the weekend.
Cheers
John
Kudos”Kudos”
Moderator
Moderator
Message 18 of 20
Re: BT Sport
Hi @DCDC Is the BT Sport still working ok? I called yesterday and left a brief message to check if all is ok are you happy for me to close the case?
Cheers
John
Kudos”Kudos”
DCDC
Message 19 of 20
Re: BT Sport
Morning John
All BT Sport channels are working correctly therefore ok to close file.
Thanks for uyiour patience and support in remedying the fault.
Dugie
Moderator
Moderator
Message 20 of 20
Re: BT Sport
Hi @DCDC,
Thank you for posting back and confirming BT Sport is working.
Cheers
PaddyB
Community ModeratorPaddyB
Kudos”Kudos”
