Tracker1
Newbie
Message 1 of 3
BT Subscription channels unavailable
I recently noticed that I was unable to receive BT sports or any other subscription channel (e.g. Discovery etc). When I attempt to access one of these channels the title bar is displayed but no sound or image. A pop up appears stating there is a broadband issue between the box and router.
There appears to be no issue with the broadband signal to the box. The box settings menu confirms the connection and I ran the re-connection wizard to check. I can receive Netflix and Prime through the You View Box and can also access BT Sport on Demand as well as the other subscription channels I am unable to access 'live'
I ran a software update to no avail and also did a factory reset without success. I can receive all the freeview channels including HD.
Can anybody shed some light on how this issue may be resolved? Thanks.
2 REPLIES 2
Andy005
Message 2 of 3
Re: BT Subscription channels unavailable
Hi @Tracker1 , restarting your Home Hub should resolve this, I've had this myself.
Moderator
Moderator
Message 3 of 3
Hi @Tracker1  and welcome to the community.
I'm sorry you're having problems with the subscription channels. Have you tried the advice posted by @Andy005 ? Has it helped? Can you post back and let us know how you're getting on?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
