Message 1 of 4
BT TV Ariel
Hi,
I am now a bt you view customer but have previously been a sky customer with a dish etc.and can only watch freeview channels on using an old sky box. The aerial cable/sky cable we have that seems to produce the freeview channels on the sky box does not seem to work with the YouView box when I plug it in.
Any tips to get all freeview channels on the YouView box?
3 REPLIES 3
Message 2 of 4
Re: BT TV Ariel
You need to get a regular TV aerial installed for the BT box and should NOT plug in a Sky dish feed into a tv aerial socket.
Fibre 2 Unlimited using BT Hub 6A with BT TV Box Pro (UHD/HDR).
Message 3 of 4
Re: BT TV Ariel
Hi @mglmour, sorry that won't work your TV box needs to be connected to a TV aerial. We've partnered with a specialist aerial installer called Total Support Group who will fit an Aerial for £80 for BT TV customers.
Message 4 of 4
Re: BT TV Ariel
Point of nomenclature: "freeview" is specifically free to view channels from terrestrial televison. Free to view (FTV) channels from satellite television are called freesat or freesat from Sky .
