Message 1 of 3
BT TV Box 4K problem
Just wondering if thee is a fix for this..? Box turns on, shows red for 15 secs then goes off but no lights after this and nothing happens on screen. Tried 3 times and same result. New box time? Do I report to BT direct ?
2 REPLIES 2
Message 2 of 3
Re: BT TV Box 4K problem
Try a maintenance mode reset.
** I'm no longer active on the forums. **
Message 3 of 3
pressed down button then power and the box 'woke up'
