Message 1 of 2
BT TV Box Maintenance Loop
Switched on the Tv and BT TV Box as normal and up comes a screen saying Box Maintenance, choose a setting and reset, Whichever one you do the box says its  resetting, goes blank then comes back up on the same maintenance page and just carries on in a loop not even giving you the option of not doing the reset.
1 REPLY 1
BT TV Expert
BT TV Expert
Message 2 of 2
Re: BT TV Box Maintenance Loop
@phillipstandfield
Sorry to hear you are having problems. If you send me your landline number via a private message then I'd be happy to have a look into the problem for you. Thanks.
