Anyone know how to get the BT You view box to update .It says update available your box will restart when we are finished and a couple of hours in and it is still at 0 % complete . Is it okay to switch off completely or will this mess it up. Any help from anyone please. Thanks
Solved! Go to Solution.
Hi @SandyS
yes try power cycling it; switch off at the back, wait 30 seconds, switch on again. With luck, it will then go into its update cycle, and succeed.
Mine does the same. Update progress sits at zero... I just leave it on this screen for 15 minutes and then power cycle. When the box reboots, it confirms that the update is complete
