Message 1 of 4
BT TV Box lost all recordings but still showing on app
Our BT TV Box was in Maintenance Mode when switched on this morning and following prompts to a software reset (recommended) our entire recordings library was gone. I use the BT TV app and strangely all of the recordings are still showing there. I have tried another Maintenenance Mode / Internet reset but still nothing. Any help greatly appreciated!
Ben
3 REPLIES 3
Message 2 of 4
Re: BT TV Box lost all recordings but still showing on app
Hi @Ben36
it may be the Youview/BT box is no longer paired to that mobile device .
So whilst the mobile device app may think that it is still paired to a  Youview/Bt box that particular registered device may as a result of the forced resets no longer be active and a “new” registered device now exist.
Message 3 of 4
Thanks @zulu17
I assume there is no way to retrieve our recordings on the bt tv box?
Message 4 of 4
@Ben36
Retrieving old recordings is possible for SD ones only as HD are encrypted.
It requires removing the HDD , mounting on a Linux computer and copying off the recordings & probably encoding them to a different video format to play either on a computer or a smart TV.
I can go into more detail via a private message if you feel that approach might work for you.
