Megadethmaniac
Message 1 of 4
BT TV Cannot watch TV fro an entire episode without complete loss of signal
Watching  a channel on Tv tonight, not often I do (I`m getting 16.4 down and 4.95 up on speed checker ) yet I cant watch an hour long episode of TV  through the box????????   Its completely broken down twice. Just pixellates then goes to black screen for 3-4 minutes.  I pay a feckin fortune for the service frankly it should be better.
3 REPLIES 3
TimCurtis
Guru
Message 2 of 4
Re: BT TV Cannot watch TV fro an entire episode without complete loss of signal
@Megadethmaniac
Any channels in particular?
If it's the free channels them it's an aerial issue so it's important to know the signal strength & quality on those channels.
If it's subscription channels it's important to know how the Youview box is connected to the router.
Megadethmaniac
Message 3 of 4
Its the Subscription channels eg National Geographic Car SOS i an yet to get through without loosing signal.
As for the method of connection TV box- router , its hard wired Caat5 / ethernet cable.
Gemma_P
BT TV Expert
Message 4 of 4
Hi @Megadethmaniac,
Sorry you are having problems with the TV service.
If you send me your landline number via a private message and I'll be happy to look into the problem for you. Thank you.
