Liquoriceman
Message 1 of 2
BT TV Extra Box subscription option not available?
I have a spare 2nd YouView box after upgrading to a UHD box last year and read on the forums that you can subscribe for a 2nd BT TV box for £5 a month, however the only option now available when looking through the upgrade options is for the BT TV App Extra at £5 per month. Is this the same thing or can you not have a 2nd physical box subscribed anymore? The BT TV App relies on Chromecast which my older Sony TV doesn't have.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT TV Extra Box subscription option not available?
Hi @Liquoriceman,
As long as both Youview boxes have been provided by BT, you can have BT Extra box at £5 per month.
I'll be able to order that for you. You can send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
