Message 1 of 2
BT TV Extra Box subscription option not available?
I have a spare 2nd YouView box after upgrading to a UHD box last year and read on the forums that you can subscribe for a 2nd BT TV box for £5 a month, however the only option now available when looking through the upgrade options is for the BT TV App Extra at £5 per month. Is this the same thing or can you not have a 2nd physical box subscribed anymore? The BT TV App relies on Chromecast which my older Sony TV doesn't have.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: BT TV Extra Box subscription option not available?
Hi @Liquoriceman,
As long as both Youview boxes have been provided by BT, you can have BT Extra box at £5 per month.
I'll be able to order that for you. You can send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
