Showing results forย
Search instead forย
Did you mean:ย
mechatour
Message 1 of 6
BT TV Remote code incorrect for new Hitachi TV
Hi all.
I've recently bought a Hitachi TV in the Black Friday deals from Argos (43HK25T74U)
I'm having problems setting up the remote to work with the TV. After doing research before posting here, I've tried the following brands (codes):
Hitachi (2424)
Hitachi (1793)
Sharp (4848)
Vestel (2811)
None of these work. Are there other codes I can try without going through all 28 pages of the PDF? ๐Ÿ˜ƒ
5 REPLIES 5
Distinguished Guru
Distinguished Guru
Message 2 of 6
Re: BT TV Remote code incorrect for new Hitachi TV
Does the Tv indicate in which country it was made ?
mechatour
Message 3 of 6
Thanks for replying,
There's nothing that shows this. The sticker on the back specifies Hitachi Europe with the address in maidenhead which I'm guessing is no use!
I've still got the packaging too and no mention there either or in the manual.
Thanks.
mechatour
Message 4 of 6
Any idea anybody?
Thanks.
1967Bhoy
Newbie
Message 5 of 6
Hi, did you ever have any joy getting the code. I've just bought a Hitachi from Argos and can't get the codes to work either :mansad:
Distinguished Guru
Distinguished Guru
Message 6 of 6
As Wikipedia article
https://en.m.wikipedia.org/wiki/Vestel
indicates it is likely that the manufacturer of that brand is Vestel so possibly codes used for other Vestel models might work.
