Topazali
Message 1 of 13
BT TV UHD not receiving AMC HD channel
Hi, I've just subscribed to the Total Entertainment package but cannot get access to AMC HD channel. I can get the SD channel but not HD. Can anyone help please?
12 REPLIES 12
Message 2 of 13
Re: BT TV UHD not receiving AMC HD channel
The quickest way to get this sorted would be to contact the  online TV orders chat team
Topazali
Message 3 of 13
Thanks. I have tried both the online chat and going through 0800 800 150 but no one could help unfortunately. I saw a similar thread here from April so thought I would try here next!
rarmitage124
Recognised Expert
Message 4 of 13
What does it say when you go on the channel have you pressed OK when on it to see if that works?
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
Message 5 of 13
If it does not show up on the guide at all try maintenance mode
Topazali
Message 6 of 13
It shows up on the guide but displays "This channel is not available with your current BT TV subscription" when selected.
BT have confirmed that the channel is included with my 'total entertainment' subscription but can't explain why I'm not receiving it.
Message 7 of 13
Run a maintenance mode without deleting recordings
I found it to be effective when the guide wouldn't work
Moderator
Moderator
Message 8 of 13
Hi @Topazali Did you get the AMC HD channel sorted?
If not we will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Topazali
Message 9 of 13
Thanks John. I've sent you a message.
Moderator
Moderator
Message 10 of 13
Hi @Topazali,
Thanks for sending over the details. I tried calling, sorry I missed you. I'll look into this and will be in touch once I have any updates for you.
Cheers
David
Community ModeratorDaveM
Kudos”Kudos”
