dgulliver
Message 1 of 3
BT TV Upgrade
Hi,
I have had my TV package and equipment for 6.5 years, the you view box and remote are encountering issues such as:
  • Some buttons on remote not responding
  • YouView box not connecting to internet
I have changed batteries in remote and performed factory reset of youview box.
If I upgrade my TV package will I get a new youview box and remote?
I've tried emailing the bt shop to see if the new remote will work with my viewbox but no reply.
thanks
Darren
2 REPLIES 2
NigelB72
Recognised Expert
Message 2 of 3
Re: BT TV Upgrade
If you have an active BT TV subscription call BT and they should send you a new box
DarrenDev
BT Sport Expert
Message 3 of 3
Re: BT TV Upgrade
All YouView boxes work with all current YouView remotes, so if a replacement remote control is all you need then you can buy from the BT Shop. Having said that though, it's worth giving us a call about your box issues, and maybe review your package at the same time - subscriptions have changed a lot in 6.5 years.
